光伏测试网论坛-一种高效MWT晶硅太阳电池工业加工新概念-晶硅光伏技术|光伏|太阳能|PV|技术|质量|认证|标准 - 光伏测试网 /> " /> " />
查看: 11659|回复: 2
isunlicai 发表于 2013-5-22 22:22:06 |只看该作者 |倒序浏览
ABSTRACT:
This work presents recent progress in research on multicrystalline silicon solar cells based on the HIP-MWT concept, a simplified structure for high-performance metal wrap through cells with rear surface passivation. With the simplified approach, no structured rear emitter is required as the rear dielectric acts as an insulating layer to isolate the n-type contacts from the p-type base. The fabricated large-area HIP-MWT solar cells with Al2O3 rear surface passivation and screen-printed contacts show conversion efficiencies of up to 18.2 % (confirmed) and clearly outperform both H-pattern PERC and MWT-BSF reference cells in terms of efficiency. The reverse bias behaviour of the cells is investigated using dark lock-in thermography and reverse current-voltage data.
MWT工业加工新概念.pdf
424.37 KB, 下载次数: 2
shortzgd 发表于 2013-5-23 13:53:34 |只看该作者
了解了 谢谢!
isunlicai 发表于 2013-5-23 15:22:25 |只看该作者
了解了 谢谢!
不客气,共同学习~
