光伏测试网论坛-光伏组件的PID机理和测试方法-PID 测试专题|光伏|太阳能|PV|技术|质量|认证|标准 - 光伏测试网 /> " /> " />
查看: 14870|回复: 0
光伏组件的PID机理和测试方法
isunlicai 发表于 2013-5-23 21:48:09 |只看该作者 |倒序浏览
Over the past decade, degradation and power loss have been observed in PV modules resulting from the stress exerted by system voltage bias. This is due in part to qualification tests and standards that do not adequately evaluate for the durability of modules to the long-term effects of high voltage bias experienced in fielded arrays. High voltage can lead to module degradation by multiple mechanisms. The extent of the voltage bias degradation is linked to the leakage current or coulombs passed from the silicon active layer through the encapsulant and glass to the grounded module frame, which can be experimentally determined; however, competing processes make the effect non-linear and history-dependent. Appropriate testing methods and stress levels are described that demonstrate module durability to system voltage potentialinduced degradation (PID) mechanisms. This information, along with outdoor testing that is in progress, is used to estimate the acceleration factors needed to evaluate the durability of modules to system voltage stress. Na-rich precipitates are observed on the cell surface after stressing the module to induce PID in damp heat with negative bias applied to the active layer.
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?马上注册
